- - 82-70 b's
Run the sweep or table independantly by cams in front and they work smooth. The second the table and sweep try to run simultanous they both freeze and growl till overload. So far heres what we have done.
-replaced Master Breaker on control box.
-replaced circuit breaker on main power panel
-replaced both sweep and table capacitors
-put gearbox and motors from working machines on
-replaced Sweep reverse switch
-replace sweep run switch
- replaced both capacitor resistors on capacitor tray
-traced every wire from C1 Plug to correct terminals in wire channel
-replaced chassis with one from a working machine
-tightened all power supply terminals from Main plug, main plug receptical, both motor plugs
-verified voltages on each pin of both motor pugs and main power plug
-checked continuity on both motor plugs for shorts.
-Had electrician trim circit breaker panel leads to ensure good common and hot lead connections.
Any one have any ideas.... this machine was working fine one day then the next it toasted the 7-10 pick off realy used in conjunction with the omni board and Accuscore.
from then on its been pure h*!! ....
Not much hair left after this one. Just as we think oh this is it ..... still no luck.
Thanks
