Old style parts
  • Old style parts
    Ok, just out of curiocity... How many of you guys keep with the latest parts trends (or try to stay on the "cutting edge" of bowling tech. And how many of you guys lag WAY behind the times (as in have old style parts, like sweep shocks, or other *OLD* style parts). I mean... on these machines it gets REALLY annoying when you want to put something back together (and actually have it work correctly) but it HAD old style parts on it, and you have only newer style parts to put on it (but not a full set). Examples : Distributor ... Shaft (for the LARGE wheel) that still only has 3 holes in it (old style) along with the *old* plastic wheels. Ball return (accelerator assembly)bearings/shafts. Or as for updating... Foul lights (ok, I KNOW there are other centers out there that still use the old radarays). Or how many of us still dont have auto-score, etc.... How many still have kickers... ETC... basically, just trying to see who's who when it comes to tech [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
    Re: Old style parts
    <font size="2" face="Verdana, Helvetica, sans-serif">Many of those old style parts often work better than the new and improved ones. Just ask an 82/30 mechanic. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
    -- Larry
      Re: Old style parts
      Like the Super Clutch?!? [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img]
        Re: Old style parts
        <font size="2" face="Verdana, Helvetica, sans-serif">Let's not go there... [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
        We do a little of both... some of the "new and improved" parts really do help the operation of the machine or make it easier to work on... others were royal disasters that should have never happened. If something new comes out that looks like it may be something we're interested in, we'll purchase 1 or 2 of them and try them on a machine or pair... if it works out, we'll start using them. If not, well, we ate the cost of some useless parts... but it usually works out.
          Re: Old style parts
          Cast iron paddles [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
          JK
            Re: Old style parts
            hehe, we still have some in a box in the back. Not that we use em :p I think I posted a pic not too long ago of one
              Re: Old style parts
              Yes, ask an 8230 mechanic. Some of the new stuff is a blessing. We have converted to open-pinwheels with magnetic clutches and kidneys. Have upgraded our 6525 chassis with Omega-tek boards nad eliminated the stepper relay. We also Have gone to Solid State contactors in the chassis. They all work great and cut down on hassles!
              Other things like solid state start switches can work for some but not for others. Right now we only have 4 spare centrifugal mechanisms left for our GE combo motors and NOBODY in the world has any for sale!
              I would like to try to get my head mechanic to buy us an infra-red pin counter to try sometime soon. The omegatek counters are a little crazy sometimes!!
              As far as the old stuff goes, these machines ran with most of those types of parts for 44 years...you can't beat 'em!!!
                Re: Old style parts
                What G-man said.
                I'm lucky enough to still have a good relationship with the Reno Hilton. I suggest new parts for them to try &amp; let them spend their much larger budget on the experiments. They also have far greater lineage than I do. They can test a part in a month or 2 that would take me years to evaluate.
                  Re: Old style parts
                  I put this topic into 3 categories:
                  1. AMF's new design of an original part. These parts usually supercede the original in availability, and sometimes get a new part #.
                  2. AMF's optional enhanced parts. (Super Clutch).
                  3. Parts that are regular production on later or current production machines, but can fit or be adapted to fit on earlier models (ie: 82/90 or 90XL parts for 70's)
                  Examples:
                  Category 1:
                  - Distributor rear carriage casting, rocker arm, &amp; rocker shaft.
                  - Dist. carriage belt runner, with the 1/4-20 square head set screw for retaing the pin guide wires.
                  - Trip Rod and support casting.
                  - Table support posts.
                  - Table torque tube and clevis (and drive housing).
                  - Respot cell: yoke assembly top plate; finger; finger insert; frame; 5/16" diameter pivot stud.
                  - Curtain Rod and grommet.
                  - Bin stringers.
                  CATEGORY 2:
                  - Various repair kits (yoke; rear roller shaft)
                  - Adjustable pulleys.
                  - Universal stamped steel pit support bracket.
                  - One-piece plastic blow-molded bounce plate. (Hope nobody still has any of these).
                  - Did someone mention super clutch??
                  CATEGORY 3:
                  - Distributor support channel and cross bar.
                  - Various tensioners in the ball exit system.
                  - PBL.
                  - 82/90 Angle iron (not stamped) pit support bracket.
                  - 90XL pinwheel frame &amp; distributor support for 82/70's.
                  - The big daddy of them all: 82/70XL UPGRADE.
                    Re: Old style parts
                    Originally posted by Dutch:
                    What G-man said.
                    <font size="2" face="Verdana, Helvetica, sans-serif">Hey Dutch!
                    I worked there a couple of years in the late 80's (when it was the MGM and Bally's). We'd often try new stuff or come up with mods of our own.
                    I have some old photos of the shop (right before they installed autoscoring). I'm wondering if it's changed much there over the years.
                    -- Larry
                      Re: Old style parts
                      Well not worked on anything newer than my ol 30's dunno whats out there!!!
                      However, we are given respot cell gripper pads that are stiff grey compound and take ages to bed in properly, if a lane has more than a few cells with these on it tends to black out a lot due to the pressure being exerted against the table.
                      Love it when someone does a bodge repair and uses a metric nut/bolt etc and leaves it until I gotta change something and come across it with my imperial tools!! the joy/
                      kev
                      If Wile E coyote has enough money to by all that Acme crap why doesnt he buy his dinner?
                        Re: Old style parts
                        Larry,
                        I think I was still working up front while you were there. Which Larry are you?
                        E-mail me: dutch@775.net
                          Re: Old style parts
                          i actually think its kinda cool to still have a few relics chuggin along, but for the most part, i update as needed, and as $$$$ will allow.
                          i took over this center 2 1/2 years ago now, i paced my self and the first three projects on my mind were
                          1) replace vantage dampners with AMF OEM style &amp; replace ragged carpets with Vantage Premiums.
                          2) replace allen bradley relays with new style (got bit on that one, bought the Vantage/GE's cuz they were $40 cheaper, well, they only seem to be lastin 18 months for me, AMF/Seimens only from now on)
                          3) replace centrifigal motor switches (in particular combo's) with SSSS's
                          after my first year here, boss talked to me cuz i wasnt spending enough money?? [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] so boss bought me a house of humpacks and automated bumpers.
                          so since, i havent hesitated at buyin too many of anything, now grapevine rumors are im spendin too much, of course. im sure all of head mechs here saw that comin, hehe.
                            Re: Old style parts
                            my latest little chang-over/upgrade fad is replacing cushion, dist belts, and front roller stuff over to Mr Fox's products, and replacing the Vantage/GE chassis relay's with AMF/Seimens. But i dont just go changin out for the sake of doin it, i wait til the old breaks, or is at least on its deathbed before replacing, get the most $$$$ i can out of the old stuff.
                              Re: Old style parts
                              never actually seen-'em in person just in old manual photos- DIE-CAST RESPOT CELL FINGERS, anybody have any of those? Steel fingers bend when there is a table jam and sometimes still work-I would imagine the cast fingers would just break
