two b.e. motors run off one machines chasiss ?!?! how?
ok on 21&22 this thing has come up where 22's b.e. motor will run off 21's chasiss when I turn 21 on but when i turn on 22 21 will not run off 22's chasiss so its a one way thing? can't find anything wrong any ideas??! [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]Tags: None
Re: two b.e. motors run off one machines chasiss ?!?! how?
Ok, disconnect the BE motor plug on 22, just to check it's not electrical.
My guess is the problem is in the lower PBL pulleys. Probably the clutch pulley on 22's side.
If you remove pit belt off 22 also, you can see the pulley spinning. This is quite common, but strange when you see it for the first time.
Worn LBS Rudder Cams
Back after 10 years with my mini lane
Hey guys! After building my lane 10 years ago I had to relocate for work and could not take my lane. It has been in storage ever since. I finally was able to bring it down...
The AMF dude
Transformer smokes
I hava a tarnsformer that started smokeing. I replaced the transformer and it runs a few seconds and starts to smoke again. Any Ideas?...
Turret 1-7-10 problem
