Distributor runner removal
  • Distributor runner removal
    Here is a pic of a distributor with the runner removed. This is the best dist. mod ever.
    Also pictured is the EBN belt....it is the best.
    If you look at the ball lift you will see the Lifelong ball lift link. These are sturdy as an anvil.
    [img]<a href="http://hometown.aol.com/thunderbowltwo/myhomepage/ebn.jpg?mtbrand=AOL_US" target="_blank"><a href="http://hometown.aol.com/thunderbowltwo/myhomepage/ebn.jpg?mtbrand=AOL_US" target="_blank"><a href="http://hometown.aol.com/thunderbowltwo/myhomepage/ebn.jpg?mtbrand=AOL_US" target="_blank"><a href="http://hometown.aol.com/thunderbowltwo/myhomepage/ebn.jpg?mtbrand=AOL_US" target="_blank"><a href="http://hometown.aol.com/thunderbowltwo/myhomepage/ebn.jpg?mtbrand=AOL_US" target="_blank"><a href="http://hometown.aol.com/thunderbowltwo/myhomepage/ebn.jpg?mtbrand=AOL_US" target="_blank"><a href="http://hometown.aol.com/thunderbowltwo/myhomepage/ebn.jpg?mtbrand=AOL_US" target="_blank"><a href="http://hometown.aol.com/thunderbowltwo/myhomepage/ebn.jpg?mtbrand=AOL_US" target="_blank"><a href="http://hometown.aol.com/thunderbowltwo/myhomepage/ebn.jpg?mtbrand=AOL_US" target="_blank">http://hometown.aol.com/thunderbowltwo/myhomepage/ebn.jpg?mtbrand=AOL_US</a></a></a></a></a></a></a></a></a>[/img]
    Re: Distributor runner removal
    won't the pins get caught under the dist. belt or maybe even wedged between the belt and guides?
      No, the pins orientate awesome with the belt runner off of it. It sure beats having the pin fall over the side or having a pin stall on the distributor. I encourage you to give it a try.
        Do you have some more pics..maybe you have also a pic of the ballift ?
        thx
        Donj
          thx
          Donj
          <font size="2" face="Verdana, Helvetica, sans-serif">King got a new toy for Xmas as mentioned in another thread, I'm sure there's plenty more pics on the way [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
            [img]http://pic2.****************//VOL26/934456/1718790/23196389.jpg[/img]
            Awh God, 1000 posts..
            So it goes.
              Welcome to the 1000 post club.
              Sorry....my webspace is full.......no more pics to post.
              JK
                I tested those belts once,turned my pins yellow.
                  <font size="2" face="Verdana, Helvetica, sans-serif">Vinson, not sure what belt you tested but the material that these are made from is oil and chemical resistant. It's virtually impossible for them to do any thing to the pins except for "grip it and rip it"
                  Please buy MADE IN USA!
                    <font size="2" face="Verdana, Helvetica, sans-serif">[img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
                      I see you bent the **** out of sides of the O-pan too! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                      We didn’t remove the runners but we did beat them down with a pin. We found that without the runner supporting the belt, the pins wouldn’t always orient properly. We solved that problem by installing belt risers. The riser catches the pin &amp; then it settles into the depression nicely. Same thing I suppose but we didn’t have to bend the sides of the O-pan up.
                        We've been useing these dist. belts for many months without any problems. They WORK !!
                        The pin doesn't get a chance to go out any other way than butt first. I need another eight belts and then all 48 will be done.
                        Rep. Rob Bishop (R-UT)
                          Hi guys. Brand new to the site. Hope I'm doing this right. I tried removing the runner but pins did fall thru now and then. Did it to one machine at the last house I worked at and it worked great. Still trying to figure out the difference. Maybe this belt is too stretched out. Anyway too many pin jams, had to put it back in. Try again next spring.
                          Give the most difficult task to the laziest workers. They will eventually find the easiest possible way of getting it done!
                            <font size="2" face="Verdana, Helvetica, sans-serif">Looks like you're doing things just fine to me. Welcome aboard! [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                              <font size="2" face="Verdana, Helvetica, sans-serif">The thicker belts work better.
