gone picture carzy still
  • gone picture carzy still
    Qbump II's
    Re: gone picture carzy still
    Qbump's
      high section only cams
        balls spinning in kicker door, glue strip of dist belt right where they spin
        this little belt section kicked many a balls til ultimately bein replaced with a humpback
          <font size="2" face="Verdana, Helvetica, sans-serif">I have a few machines with these cams.
            Qbump XS's
            <font size="2" face="Verdana, Helvetica, sans-serif">Those heads look nice......did you sand recently?
              Landon's patented homemade thermal protection protector
                the great AMF HP bounce plate
                  lifelong beltsaver, good product
                    <font size="2" face="Verdana, Helvetica, sans-serif">Thx King!
                    Last Resurface was '97, or '99 ill check tomorrow, have guardian 22'.
                      </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Coors:
                      <font size="2" face="Verdana, Helvetica, sans-serif">I have a few machines with these cams.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Wow, neat. Never saw cams like that before
                        the termonology of the two Qubica bumper systems is a tad confusing. the website and the installers called the orange (ball wall style) bumpers the XS's, and the ones on 21 Qbump II's, even though the Logo on lane 19, and the installation manual calls THEM "Qbump II's"
                        either waq doesnt matter to me, just wanted to clarify incase someone was as confused as i am
                          Qbump's
                          <font size="2" face="Verdana, Helvetica, sans-serif">Coors, or anyone else with this style of bumper:
                          When you want to raise the bumper, do you pull it toward the approach, or push it toward the masking unit? Just had one installed in a center that I work for ( by a local with constuction background) it is set up to be raised by pushing the bumper toward the masking unit. Is this correct , or backward ? Thanks, MARK
                            These are automated, ran by air, they are installed to raise toward the mask. if you dont have automatic, they are suppose to pull up back toward the foul line, that's how it was explained to me. but so long as they work, Im sure everything is fine.
                              Are the Qbump's any good ?
