I have a 82-70 with mp chassis. The machine will run good for a couple of days then when you turn off the machine and turn it back on the back-end motor runs backwards. You cant use the chassis or the control box in the back to do anything. I have changed complete chassis off of another working machine and put that chassis on the other machine still have the same problem, so I know it isnt in the chassis. I have checked all the c-1 plugs they seem to be ok. I have also replaced all of the switches in the control box. It seems when we finally get it going the machines goes into like shadow bowling no table or sweep, but the pit runs. You unplug the main power from the machine and plug it back it the pit runs backwards. I have also changed the back-end motor. It just seems to come and go. But it only happens when the machine is cut off and then back on.
Thanks for your help
