Carpets and Prodigy
  • Carpets and Prodigy
    I've been using Prodigy now for about 8 months now. All of a sudden a number of my carpets are squeeking as they go over the bounce plate. Sounds like a bearing is going bad, but there not. If I go to the common side, while the carpet is running and wipe the inside of the carpet with a rag it goes away for a day or so. It's happening on different brands of carpets, Vantage and Longwood. Just wondering if anyone else is having this problem.
    Thanks
    AMFDOCTOR
    The Doctor Makes House Calls
    AMF DOCTOR
    The doctor makes house calls.
    Re: Carpets and Prodigy
    No problem here...but I cannot hear anything due to my front rollers clunking....lol
    JK
      I had the same problem a while back, sounded like chirping birds. I also work at a BRC center and we have this 4" wide translucent tape made by Cadillac Plastic's {they are on the web}. we use it for repairing deck chutes. It is .015 thick and very long lasting. Kat posted for me a while back & explained it's due to carpet wear on the high side. He was right. I pulled the carpet away from the side plate {pop the front roller if you want}and applied the tape to the bounce plate including the steel angle plate. When it wears down in about 4 months, it won't leave a gooey mess and you can stick another length right over the top with out removing the old. This tape has a backing on it that you remove when you apply it. It works great for me-hope it works for you. Bill
        Hey Doc- the only time I had that problem was when using the 3-ply carpets from AMF. The backing would wear off and the rubber in the middle of the carpet would rub o the bounce board and chirp. Not sure why Vantage carpets would do this though.
        Pete
          Just put the noisie ones as far away from the shop as possible.
          Remember no one is perfect no matter how good we are!
