Tip
  • Tip
    Here is a tip that has helped us since we installed the "Spider Relays"(sweep reverse kits).
    Please give your insight if it could have any negative draw backs. Thanks
    Peanut
    Re: Tip
    Peanut...
    As usual, great idea. We get alot of "hanging bananas" calls due to false out of ranges casued by flat gutter pins.
    Question though: Which spring did you use and how far apart are the holes on the casting?
      Re: Tip
      The only theoretical drawback would be the 'weakening' of the table casting, which, I don't believe would be an issue.
      Fever [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img]
        Re: Tip
        I will post the spring number and the hole template....it might be a couple of days.
        Peanut
          Re: Tip
          I would love to know how to get these spider relays [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img] Are they available commercially? Great idea with the spring Masternut, even with centers that do not have the relays installed. We get a few of these calls a week. Thats a few less calls a week right there.
            Re: Tip
            geminix
            We got the relays from Ed Fox At EBN Services.
            1-888-435-6289.
            Nice kits easy to install.
            Peanut
              Re: Tip
              The spring is a good option. When I was at Hilton, we had plastic wedges made that we screwed on. Worked well but screws broke after a while.
              In my new place I've just taken my hand held grinder & buzzed off the lip that it catches on. Don't know why they put it there anyway. It isn't on the other side.
                Re: Tip
                Can someone explain what the "spider relays" are? Or is this just a slang term I am not familier with. Thanks [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                  Re: Tip
                  What the Spider Relay does is put the sweep into an auto reverse when the 82-70 machine detects an out of range. The only problem we had with it was when there was a pin left standing in the gutter and Masternut was so kind to solve this issue for us.
                  Thanks William! (BIG kiss)
                  Please buy MADE IN USA!
                    Re: Tip
                    With this mod peanut has got over the 4000 fps on a 70 [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                    Seriously.....how did you think of that.
                      Re: Tip
                      How do you get the curtains to hot hold pins to effect scoring?
                      I cut them like your earlier mod and some of them ripped?
                      NUT?
                      JK
                        Re: Tip
                        Ed
                        With these spider relays, if the sweep does an auto reverse, what about pins left on the pin deck? Do the bowlers complain? More info please.
                        Give the most difficult task to the laziest workers. They will eventually find the easiest possible way of getting it done!
                          Re: Tip
                          Who sells this Spider Relay and how much are they? I'll order a few to try out.
                            Re: Tip
                            Originally posted by RGP:
                            Ed
                            <font size="2" face="Verdana, Helvetica, sans-serif">Deadwood is left on the deck.
                            JK
                              Re: Tip
                              Ed
                              <font size="2" face="Verdana, Helvetica, sans-serif">The dead wood will be left behind...that is if there is any. From the tests we ran 3 out of 5 out of ranges didn’t have dead wood left on the deck and made the spare playable. During birthday parties is when 90% of the out of ranges occur and the kids couldn’t care less if there is dead wood or not. It greatly reduces the machine stops and is a real time saver.
                              <font size="2" face="Verdana, Helvetica, sans-serif">We..EBN Services carry the Spider relay kits and there is an unconditional guarantee with all of our products. There is absolutely no risk after purchase. They are $65.00 per machine and the entire kits installs in just a few minutes.
                              For more info you can call 888-435-6289 or e-mail edfox@ebnservices.com
