Bin Bumpers
Bin Bumpers
Just curious...how many out there run without the little black bin bumpers? I've removed most of mine after finding we get 1 or 2 jams a week caused by the head of a pin hanging up on either the uppers or lowers. More frequently on the uppers. On the machines I removed them (half the house) I haven't seen any calls."Where are we going, and why are we in a hand basket?"
--KatTags: None
Re: Bin Bumpers
We play it on a bin by bin basis. A fair description is we only fit the lower outside ones on all brackets. We find the pin doesn't always sit properly if they are all fitted. Maybe if the bins were slightly deeper it may not be so much of a problem. But that would cause problems elsewhere. We'll never know.
Re: Bin Bumpers
I'm in the process of yankin mine out. They cause more problems than they cure. The oil just eats'em away and makes'em gummy in no time, no matter what brand you use. Thats why I pulled my cup liners.
Re: Bin Bumpers
i just have a question about this wont pulling them out cut up you pins or mabey ding them i know at our center they do get gummy and are ruinned after a couple of weeks but we have been replacing them but if it wont ding the pins i might pull ours also.
scotty
Re: Bin Bumpers
scotty"Where are we going, and why are we in a hand basket?"
Re: Bin Bumpers
Removing the 992 bumpers really make a difference when shuttling, and it doesn't hurt the pins as long as there are no sharp edges on the cradles. However, you end up with two problems: one immediate and the other long-term.
First, pin feed becomes noisier. If you can deal with it, no problem.
Second, the whacking of the pin heads eventually will crack the cradles or the stringers to which they're attached. Starts to get expen$ive in time.
Suggestions:
1) If you remove the uppers, don't make the mistake I did by bending the "ears" down. This results in a sharp edge at the hole which will damage the pin heads.
2) If you remove the lowers, try lining the cradle with something like material from old carpet belts or curtains. You'll have to glue them on.
3) Replace the original cradles with ZOT's adjustable ones. They're great and have a plastic one-piece curved saddle which allows the pins to slip out easily. The mounting holes are slotted so you can raise each one if needed to clear the tops of the spotting cups.
Re: Bin Bumpers
The long term effect would probably be way down the road. It would take some time to crack them.
Great suggestions BowlEquip. I have looked at the Zot cradles, do you have any experience with them?"Where are we going, and why are we in a hand basket?"
Re: Bin Bumpers
The uppers we have removed, the lower ones (in the straps) are left on.
If they get sticky from lane conditioner, etc.. on them, just pat them with a pro-slide bag... it makes them nice and slick so the pins don't stick to them, and the gumminess goes away...sometimes not to return for a year or more. (I found that out by accident... I did it during a league to keep pins from hanging up on them, forgot about it, and remembered several months later while doing bin work on that machine... the rubber bumpers I hit with the pro-slide were just fine.)<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
