Could someone give me the size of the carpet belt?
Carpet Belt
Re: Carpet Belt
I'd guess someone will have to actually measure one... I don't think the actual material dimensions of the belt are even shown anywhere in the books... an AMF machine carpet belt is an AMF machine carpet belt, no matter who the manufacturer of it was... so there was never a need to specify dimensions.
Can anyone jump in a machine with a tape measure? I don't go down to the bowl too often anymore, or I would...<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
Re: Carpet Belt
we use 114" carpet drive belt on all of our machines, it also depends on if someone has changed the pulley on the gear box, 112" belts would work however, the 114" is easier to remove and replace.Remember no one is perfect no matter how good we are!
Re: Carpet Belt
It sounds to me like he wants the dimensions of the carpet itself. Like I said, I don't know them offhand... there's only one size for a carpet (unlike the drive belts), so there's very little need to know the exact dimensions of it.<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
Re: Carpet Belt
Originally posted by William Elshire:
Thanks all...I was looking for the actual size of the Carpet Drive Belt.-- Larry
