8800 GOLD HBR
  • 8800 GOLD HBR
    Does anybody have any pics of the 8800 GOLD HBR?-horizontal ball return, I think, that they could post?
    Re: 8800 GOLD HBR
    Just a PBL, laying down.
    AMF should have raised it enough so that pins fall out between the kickbacks instead of going into the underground.
    Engineers.....
      Re: 8800 GOLD HBR
      only have a photo off the top of the m/c showing a flat top and a guard screwed down where the pbl should be..
        Re: 8800 GOLD HBR
        a little more then a pbl laying down. there is a cradle that shoves the ball out of the ball exit and into the hbr. There is also a lock mechanism here to prevent pins from entering (although it didn't always work). There is also a dedicated motor for the "ball accelerator", this motor also drives the cradle which is turned on and off with a clutch. Also, there is a sensor above the exit and a relfector below the exit. A ball will break the beam, but a pin will not.
        When the beam is broken a signal is sent to the cradle clutch, which engages and shoves the ball out. The ball enters the horizontal accelerator and is shot up the underground return. i have a copy of the manual if someone emails me instructions on how to post pictures, i will post some of the pictures.
        i also have a few pix of a result of when a ball gets jammed in the hbr. not a pretty sight.
          Re: 8800 GOLD HBR
          xl2ockl3ottomx pretty much hit it head on with the description.
            Re: 8800 GOLD HBR
            The Fast Trac
              Re: 8800 GOLD HBR
              Trying to post this picture. Not sure if it will work. Not the greatest resolution either.
