Mods Backend motors
Mods Backend motors
does anyone have a pic of the mod where you run two lanes on one backend motor i want to show my boss man this one but not sure how its made willhill24@ec.rr.com [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img]IF IT AINT FIXED YOU PROBABLY BROKE IT!!!!!!Tags: None
Re: Mods Backend motors
You take the caps from the back of a spotting cup along with the u bolts and sandwhich the ball lift shaft in there and tighten nuts on the u-bolt and walla.
i have used this trick a few times before to get a league through a few frames.
Just a little note though, doing this could cuase damage to one or more of the gears inside of the gearbox. it will also make the motor run hotter and if you have "shady" motors the clixon may give out or even destroy them.
Originally posted by SVLFever:
Yeah, it's called a bad ball lift clutch.
Just kidding....
Fever [img]/content/btubb/images/%%GRAEMLIN_URL%%/usflag.jpg[/img]All I want in life is to turn wrenches and climb around pinsetters/pinspotters again :/
It's a quick fix to get you out of a jam... just don't get any ideas about saving $$$ by running the backends on a pair from one motor... You'll be changing out motors every few days.
We never had to use it... 4 bolts, 1 shaft, and 2 belts isn't a big deal. Normally it only takes a matter of 5-10 mins to completely change out the backend drive... We keep 2 RH and 2 LH motor/gearbox setups as spares just for that reason. Most of the time they just collect dust... I think the last time we had to change out a backend mtr/gbx during bowling was about 4-5 years ago.<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
Did a search reading thru mods. On the note of leaving motor and gearboxes as spares collecting dust, wouldn't it make more sense to swap out your spares on a seasonal basis? Find a pair that you think might be going out, is making noise or could possibly be bad. Swap your spares and rebuild? Simialr to how brunswick always says to rotate your spare electrical equipment? I don't know, will defer to someone who knows motors a little mor eintimately than I do. Just curious...Failed safety course.Question #1:In case of fire what steps do you take? Apparently 'Friggin long ones!" is the wrong answer.
Tech Tip
Thanks to J. Shane White, Nite Mechanic at Triangle Bowl in Desota, Texas for sharing with us the following tchnical tip.
During a full house league I had a pit motor go out, and I did not have a spare. I knew from past experience with failed clutch bearings that one pit motor is strong enough to drive the pits for a pair. In a moment of desperation, I took a 3" lomg piece of 3/4" diameter conduit and cut a slit in it lengthwise. I then bent the conduit in to a U shape. After that I used a pair of U clamps to fuse the shafts of the two pit motors together. This is definitely a temporary fix, but it got me through the league, and in fact, it lasted about one day until the conduit broke.If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
Regards, Garo
AMF 82/70 Tech
I was looking over the machines this morning thinking how it would work. Are they talking about sandwiching together the 2 gear-box output shafts with 2 pin cup caps? Right behind the BE boxes where there is about an inch or 2 in between the 2 shafts?Failed safety course.Question #1:In case of fire what steps do you take? Apparently 'Friggin long ones!" is the wrong answer.
If you have an inch or two between your backend motor rear drive output shafts, you should kiss the floor behind each machine. Most 82-70's only have a half inch or less there.Prevent the problems. Don't do crash repairs.
Drywall in a bowling center: Recipe for disaster.
