pic test
Re: pic test
If you want to see the code of how something is posted, hit the "reply with quote" button above the message... it will repost the entire HTML/UBB string in the quote. When you're done looking at it, just hit the "back" button on your browser to exit the message screen without reposting the message.<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
Re: pic test
Originally posted by smalltwnguy:
Yes, I stand corrected, missed the sweep down part meaning OOR switch was activated. How is it that just some of the pins were picked up? Would it be that the pin that was standing was in the 7pin gutter and the machine went farther down on the 10pin side? Is that possible?
Re: pic test
If it's in an offspot cycle, either it didn't complete or there's a bad 2nd ball light on the mask, offspots (when complete and everything working properly) sets the machine to 2nd ball, the offspot switch and TA-2 change the ball lights.All I want in life is to turn wrenches and climb around pinsetters/pinspotters again :/
Re: pic test
It was a broken roll pin in the table drive assy! This allowed the table to try and go to the pin deck.
Since the broken roll pin did not allow the table drive link to catch in the notch that limits the table on the first ball cycle. The table activated the Off spot relay when it tried to go down to the pin deck, when the resopt cell closed they only grabbed the one pin! This was the actual call I walked into.
I guess it does look like a pin in the gutter. I should have gotten in a better position for the picture.
Thanks for the help with the pictures guys.
