I'm looking for a part number that I can't find in any manuals. Its the long thin bracket that the adjusting stop screws go into for the spot/respot cams (where the spot and respot arms rest), which also connect to the pit lite bracket. Anybody know what that part number is? I currently have ty-raps holding up a pit lite assy on lane 22 [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img] . Luckily the machine is running OK without those screw stops. Thank u in advance [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
part number needed
Re: part number needed
You could call amf and ask carl ,or just make one yourself or have one made for you. Another thought would be to find someone who has parted out machines and get one that way. Just courious. How did it come about that you would need this ? Twenty years and have never had to change one or even repair one.
#070-001-698 Angle,Pit Light
#070-001-907 Angle, R.H. Pit Light Mount
#070-001-908 Angle, L.H. Pit Light Mount [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
Mreessr, I had an idiot decide he was going to step onto it to climb up into the machine and he busted the thing clean. You are correct. I've never seen one break either and I've been at this since 1983.
Dutch, I never knew what they were for either, and I see now that they really didnt have a use, other than, I guess, to keep the arms from bending??? Like I said, the machine is running fine without them and yours obviously are [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
Felix, thanx for the part numbers [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
BG
In school, we were told the stop screws are obsolete. We removed them from each machine in school as we got to them.TSM & TSM Training Development
