INTERLOCKING
  • INTERLOCKING
    I HAVE 82-70'S WITH 5-BOARD CHASSIS CONVERTED TO OMEGA-TECH. I HAVE ONE CHASSIS THAT KEEPS INTERLOCKING. I MOVED CHASSIS AND THE PROBLEM FOLLOWED THE CHASSIS. I THEN MOVED OMEGA-TECH BOARDS AND THE PROBLEM STAYED WITH CHASSIS. THE CHASSIS HAS NEW TABLE AND SWEEP CONTACTS. SO NOW I AM CONFUSED. THE C-1 PINS LOOK A LITTLE WORN BUT SEEM O.K. THANKS FOR ANY HELP.
    BAMM
    Re: INTERLOCKING
    need a little more info....like what position is the sweep and table at when it interlocks.
      Re: INTERLOCKING
      THE SWEEP WILL BE BETWEEN THE 2 BACK ROW OF PINS AND THE TABLE WILL BE ABOUT 1/2 WAY DOWN. I THINK IT IS USUALY IN SECOND BALL NOT SURE ON THAT WILL CHECK TOMORROW.
      BAMM
        Re: INTERLOCKING
        I had a similar problem once....found an almost invisable wire hair shorting out 2 contacts in the wireway....it turned out to be a piece of wire from my wheel on the grinder.
          Re: INTERLOCKING
          Bamm, you will need to check the sweep contactor wires, make sure they arent burnt or broken, then check lower contactors, that is the sweep brake. Im sure it is one of the following. Good Luck [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
            Re: INTERLOCKING
            I agree with Pinboy. Check the lower sweep contacts. They're usually the cause of I-locks that follow the chassis.
            Also, rebuild that C-1. You'll save a lot of money on aspirin if you rebuild them any time they're even a little questionable. Use gold pins & sockets. The extra $ is worth it on the high voltage C-1. Newark stocks them.
              Re: INTERLOCKING
              sweep contacts that was it. changed the contacts out today and problem gone. i have siemens contacts and this is the first to go out. thanks the contact are enclosed so i wanted to see bad parts and took it apart and it was ugly.
              BAMM
                Re: INTERLOCKING
                try a bowl-tronics triac board. there great and only $40 to $45. NO MORE WORN CONTACTS
                  Re: INTERLOCKING
                  cool can you give me more info please?
                  no more worn contacts would be awesome!
                  BAMM
