jb
dist. skipping 6 pin
Re: dist. skipping 6 pin
I HAVE HAD THAT PROBLEM BEFORE AND I LENGTHENED THE ROD ON DIST. THE ONE FROM FRONT END FINGERS TO TRIP LEVER. WHAT I SAW WAS GOING TO THE 6 SOMETIMES THE 5 THE DIST. WOULD EXTEND AND HIT TO HARD CAUSING DIST. TO INDEX AND SKIP THE 5 OR 6.
HOPE THIS HELPS
P.S. YOU WILL HAVE TO ADJUST ONE OF THE ROD ENDS TO DO THIS. MY MACHINES I HAVE TO TAKE BOLT OUT OF ROD END TO MAKE ADJUSTMENT. DO TO ROD ENDS UNLIKE SPOT OR RESPOT RODS.
BAMM
Originally posted by clueless:
distributor is running fine until it gets to the 6 pin. gets to the 6 pin and trips right over it sometimes...but not all the time. have never had this happen before and am kinda lost. any help is appreciated. thanks
jb
-Loose eccentric Rollers
-Rocker weldment out of adj (should straddle trip shaft by 1/8" top & bottom)
-Excessive clutch tension
-Distributor belt too short
-Loose mounting of trip rocker casting at stop blade."Where are we going, and why are we in a hand basket?"
Last time I had this all I had to do was adjust the cable. When it would index forward that little bit from the 5 to the 6 the stop blade would move enough to allow it to index, put the cable in proper adjustment and not a peep since [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]All I want in life is to turn wrenches and climb around pinsetters/pinspotters again :/
Originally posted by Kat:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by clueless:
jb
-Loose mounting of trip rocker casting at stop blade.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Skipping positions can becaused buy a plethora of problems, I believe KAT pretty much listed them all.
Charlie [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]Please buy MADE IN USA!
check several things.
1.are rods parallel
2.are rollers too tight.
3.is sleeve and pinion gear free on shaft.
4.is trip stop blade and clutch lining up ok.
5.is distributor shaft bent causing rocking effect.
6.is there a washer between worm and sleeve pinion.
7.is worm worn.
most likely is that the rods are not parallel and if you look at the stop blade and the rear of the clutch you will see that they do not line up.one will be a lot higher than the other.
hope this will help you.
there are other possibilities but these are the most common.
good luck. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
Quick fix & test:
1) Clean carriage tube & rollers.
2) Put the dist in the #5 position.
3) Push carriage as far back as it will go.
4) While watching the stop blades, release the carriage.
5) If dist indexes when carriage extends, lengthen cable (rod, for you old schoolers) 1 turn at a time until it doesn’t index on its own.
6) Repeat steps 3-5 at the #6 position.
When you have more time check the other items mentioned.
Originally posted by Ed Fox:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Kat:
jb
-Loose mounting of trip rocker casting at stop blade.</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Skipping positions can because buy a plethora of different problems, I believe KAT pretty much listed them all.
Charlie [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img] </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Plethora......Ed?........that is a big word....LOL
Jeffie.....Which lane?......4?
JK
JK
JK[/QB][/QUOTE]
no, 2,4, and 6 are working at my mercy now. no problems there at all. it is lane 10 doing this. lanes have been running great though...here lately if we have 1 call a night it was a rough night. even on full or double shift nights.
