OOR
  • OOR
    we are having a problem with OOR's... is there any alternative to solving this problem without using legends pindeck treatment. ive been noticing that using the treatment is getting the pins sticky. any suggestions???
    - Jason
    Re: OOR
    I just go to my local ACE hardware & get some of they're industerial degreaser. Mix it about 50-50 with water in a 1 gallon bucket. Clean the pin decks with that 3 times a week. My OOR's are few & far between. Or if you are not having that many. You could clean the pins more often.
      Re: OOR
      Meckanic;P.A.Base coat= Your pin decks=Dirty Look'in with this stuff..but it works and may need to reapply..but I Like It. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
        Re: OOR
        we mix cv388 and water and spray the deck 3 time a week. before running the lane machine. that has reduced the oor fromm 100 to about 10. we still get them from small kids throwing 6 or 8 lb balls. but not much you do with that. a lot better than it use to be
          Re: OOR
          Ya I have done that too. Still using the ace degreaser. but put it in a 409 bottle & spraying the deck. I like to keep my decks queaky clean
            Re: OOR
            If ledgens is making your pins sticky maybe you are not using it correctly, follow the instructions.
              Re: OOR
              We started using Kegel No Pin Slide at the beginning of this season. In a 12 lane center, we were running for 30-40 OOR's a week across 14 leagues last year. Now, we run for 3-5 a week. I spray it on the decks right after a strip/oil run. Usually on Monday, Wednesday, Friday. I've been told our Amflite II pins and 11 year old synthetic surface are two reasons we had so many. But NPS has been a wonderful time saver for us.
                Re: OOR
                We started using Lane Masters pin deck spray a few weeks ago. When we sprayed the pin decks and then let the stuff dry, we would have pins that would start falling over as they were being set. Sparadic and intermitent problem, but on the lanes that have the problem, always the same pin. Checked the cups and they seem alright...but some don't look symetrical. If we wipe the deck spot off for the pin that is falling over, the problem goes away. Go figure. Any ideas what is causing this oddity??
