Cushion box
  • Cushion box
    What company is making the most durable and husky cushion box? I have had a lot of trouble the last year.
    Re: Cushion box
    Are you talking about part # 000-022-794 ?? Thats the number for a right hand machine. I like Vantage urethane blocks. If your talking about the steel box. #000-022-788 Then I cant help you much. Never have much trouble with mine. Most all my part's come from Stahl's or vantage.
      Re: Cushion box
      The steel box
        Re: Cushion box
        It does sound like the box being referred to is the cushion block box. They do seem to break in bunches... you'll get a couple broken ones in a short time, then nothing for a while, then a few more.
        We've had good luck with the Vantage urethane blocks and the steel box mountings. One thing we found that keeps the blocks from wearing is putting a light skin of synthetic grease to the inner surface of the hole in the block. Hasn't shown any signs of damaging the urethane, and protects it from wear.
        As for the steel block boxes, not much you can do except keep the bolts tight... if they're loose and the box can move around, you're going to wind up with the box tabs breaking off, or the bolts shearing off in the sideplate.
          Re: Cushion box
          It's not something i have seen a stronger part for they break if the bolts are loose as said earlier
          keep the bolts tight the rarely break
          First you clean it
          then you lube it
          then you clean it
          then you adjust it
          then you clean it
          then you clean it some more
            Re: Cushion box
            Originally posted by jfglndn:
            The steel box
            <font size="2" face="Verdana, Helvetica, sans-serif">A.M.F. is all I use and they rarely break.
              Re: Cushion box
              The steel box
              <font size="2" face="Verdana, Helvetica, sans-serif">AMF. Only had one break in six years. And was because of loose bolts.
              All my parts are AMF and a little from JCP.
              Mike
              Mike
                Re: Cushion box
                We use AMF's also. I change about one a month if that and we're a 64 lane house, they stand up well for us [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
                  Re: Cushion box
                  I don't know of anyone that's selling a beefed up box. As stated above, if you keep the bolts tight &amp; USE FLAT WASHERS, there aren't many problems with them.
                  One nice thing about them, when they do break, they're probably the easiest part on the machine to weld.
                    Re: Cushion box
                    In the same vein that I defended Vantage distributor cams and cables because they're good, I know firsthand that their 22788 box is crap.
                    I don't know if it's too thin a gauge or too weak a metal, but a favorite for returns are boxes that have failed prematurely.
                    I have experienced this myself at centers too.
                    So, if you're not inclined to change these a lot and do a lot of welding only to have it fail too soon again, buy the real AMF box.
                    Chad
                    P.S. the Vantage 22794/795 blocks are good though.
                      Re: Cushion box
                      Magic i have used the blocks before and i liked them i thing most of vantage's urethane parts are top notch especially like the vibration danpeners for the pits
                      First you clean it
                      then you lube it
                      then you clean it
                      then you adjust it
                      then you clean it
                        Re: Cushion box
                        Mod; [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] Mod: [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] ...Dutch Had something to do with this?
                          Re: Cushion box
                          that was about five years ago that i used them Have they changed any ??
                          First you clean it
                          then you lube it
                          then you clean it
                          then you adjust it
                          then you clean it
                            Re: Cushion box
                            <font size="2" face="Verdana, Helvetica, sans-serif"> [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                            Well he's right.....
                            .... and Vantage boxes made for great welding practice. Because you got lots of it. :p
                            -- Larry
                              Re: Cushion box
                              I like that Vantage quick removal block, V203 I think is the number.
                              Charley
