Franklin Combo Motor
  • Franklin Combo Motor
    Does anybody know if you can buy a new rotor and shaft for a Franklin Combo Motor? The former head mechanic broke the keyed end of the shaft off into the gearbox. The parts list paper says N/A. If you can, does anybody know the part number?
    Charlie
    Re: Franklin Combo Motor
    Our Franklin Combo Motors use 090 004 525 rotor assembly. About $50.
    RR
