Underlane
  • Underlane
    We found some damage to the tracks where the balls return to the c90. Unfortunatly we don't have a manual to identify the parts we need. I'll describe what I see the best I can. If someone could post part numbers I'd be grateful.
    The machines were installed early 1991.
    The underlane consists of a flat metal plate with a black plastic strip on eithe side, which appears to be help in place by clips. It is this plastic strip which is damaged and needs replacing.
    Any help appreciated.
    Re: Underlane
    Plastic Runner 67 FT, 167-003-122
    Spring Clip 167-002-014
      Re: Underlane
      Thanks for the quick response felix.
        Re: Underlane
        This costs £122.76
        About $214.00.
        Glad we don't replace many !
          Re: Underlane
          Do yourself a favor and and replace the whole thing rather than attempting to patch it and save a buck becaus [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img] e it will most likely come back and bite you in the a$$.
            Re: Underlane
            I hate those black strips im lucky i have the tube style now they work great also the downsweep is replaced i never really like the timber ones always scrubbing them to keep them clean
            First you clean it
            then you lube it
            then you clean it
            then you adjust it
            then you clean it
            then you clean it some more
