I have had these ball stops fail at the hinge prematurely. Some of these only last days. Have they changed the urethane formula? Does anyone know who makes a long lasting ball stop?
Vantage Sure Pik ball stops
Re: Vantage Sure Pik ball stops
Originally posted by Magic Triangle 2:
I have had these ball stops fail at the hinge prematurely. Some of these only last days. Have they changed the urethane formula? Does anyone know who makes a long lasting ball stop?If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
