Double solonoid nightmare
  • Double solonoid nightmare
    Went to the house I service yesterday.
    Double solonoid machines.
    The spot latch solonoid hook would not clear the pin in the lever.
    The only way it would work is with a smaller pin securing the solonoid to the hook assy.
    The solonoid was not replaced.
    The spot arm was in adjustment.
    My fix was to run the machine to where the hook jammmed and hammer the hook until the solonoid assy gave clearance.
    This took me an hour, but it works.
    JK
    Re: Double solonoid nightmare
    Goes to show not everything is a straight foreward fix. Sometimes you gotta do what you gotta do.
      There is a conversion kit for that, I assume that you probably know that though, it replaces the respot solenoit. It isnt the same as the newer single solenoid assy. with the carberator link, but it works. Especialy since those old respot solenoids (being a different size than the spot) are hard to find
        I'm in the process of changing my machines over to single solonoids. I've run across the problem you're talking about several times. Usually it's the link between the solonoid & the hook. The holes elongate & won't lift the hook as high as it should.
        If you have a TIG welder you can fill the elongated holes & redrill them. I wouldn't try it with anything but a TIG tho. They're cast & won't weld right with any other method.
        My most common fix for this is to grind the tip of the hook until it clears the pin. You can grind off a lot of that hook before it won't work properly.
          Dutch,
          I am not familiar with the double solenoids set up.
          Is the arm cast iron? I would assume you meant iron when you said cast and tig welder. Cast iron is tricky to weld (cant get it to hot), but it can be brazed or arced/gassed with nickel or cast iron rod. These are the only three metals I am familiar with that will stick to cast iron. I have used all three metals for welding (82/30 distributor track) breaks and broken teeth. I prefer the brass because it is the easiest to machine and holds up well, the nickel and cast iron rod are stronger but just to brittle if excess stress is placed upon the weld.
          Also, I have successfully brazed the front roller hinge holes and they stood the test of time. However, they are a PITA to re-drill perfect, even with my crude drill press jig.
          One other question is there enough meat on the elongated hole that could be drilled and install a bushing without weakening the structure too much?
          Triac
            Man I miss the TIG welder at the MGM Grand.
            Mike
              mt there is another adj for that ,you can have table stop a little higher till the hook releases ,make sure u dont go to high or it will miss shuttle and the clevis will not realease
                Triac,
                Yes, cast iron. It's the link from the solonoid to the hook that lifts the hook. At the solonoid it's 1 leg & at the hook it's 2 legs. (On a 2 solonoid machine the hook is an actual hook) It's a little difficult to describe, other than that. Does anyone have a pic?
                Mike
                <font size="2" face="Verdana, Helvetica, sans-serif">Which Mike are you?
                  I have two double solenoid assemblies that I don't need if someone would like to buy them [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img] But I service a 10 laner with double solenoid machines so I'll probably use them there.
                  Triac, I have a guy that's going to install bushings in a couple front roller hinges for me so I'm gonna give it a shot. Anyone know the proper Enviro for that??
                  Charley
                    Dutch, I believe that's Mike Mullins with AMF.
                    Charley
                      <font size="2" face="Verdana, Helvetica, sans-serif">Farley,
                      I wouldn’t recommend installing bushings in the holes of the front roller(If ithis is what your refering to). I have tried that a few times in the past and there is just not enough meat. The hole will just blow out.
                      Like I said earlier, I have had great success filling the holes with brazing rod. But they do have to be re-drilled almost perfect or they will oval real fast and it creates more stress on the link bushing.
                      I don’t know of the part # for the link bushing from enviro, but the nylon/plastics I’ve tried from quality didn’t hold up to long. I just stick to the brass links.
                      Triac
                        That would be me.
                        Mike
                          Mike
                          <font size="2" face="Verdana, Helvetica, sans-serif">Me too!!! [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img]
                          -- Larry
                            Originally posted by triac:
                            Dutch,
                            Triac
                            <font size="2" face="Verdana, Helvetica, sans-serif">Several welding outlet's offer a 'cast iron' stick now, that I have had great results with. You will need a decent welder though, the Craftsman low buck buzz box won't do it! There is also a few good aluminum rods out there too, so the fixes that were impossible are possible now!
                            TIG and Brazing are fantastic, but nothing beats a good MIG and gas, not a fan of gasless wire!
                            It's been awhile but I have much more to share!!!
                              Reaming is the only way to hold size. I would "step ream" meaning starting with a smaller size....say .375 to .4375 to .500 if that is the final outside dimension
