[img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] Starting with a broken strap pillow block on the table torque tube I have had no sucsess in getting the pins back on spot. I have used the locating tool to adjusted the table to center the 1 & 7 & 10 pins, tie rods(getting 5/16ths distance between pin deck & table)at the lowest point which changes the center of the locating tool. This also makes the 10-pin side table support assembly lean in noticably. When this is done the pins are at least 1 1/2 inches too far forward. This also changes the adjustments for the spot & respot rods.
Still no sucess. I need to start ALL over with a correct plan on resetting the table from scratch.
Whatever help you can offer would be greatful.
