Ball lift / kicker assb. Assistance
  • Ball lift / kicker assb. Assistance
    Einstein's of the 82/70's. [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]
    We have an issue w/ "pad starter" sliding back up.
    Eventually it moves far enough up to hang balls in the hole. [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img] The kicker(s)have no problems getting the ball in and balls return fine when the pad is in properly. Hence to say, pad moves up, no balls return. Last about 12-15 balls before the calls start. [img]/content/btubb/images/%%GRAEMLIN_URL%%/mad.gif[/img]
    Any suggestions on how to make this pad stay in place? But, be removed when needed for replacement when wore-out?
    Thanks Gents [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
    If its SIMS, its only a game.
    Just hit reset.
    Re: Ball lift / kicker assb. Assistance
    I glue them! This works for me. I hope that you get the problem solved
      Sheet metal screw in the side of the starter pad housing.
        <font size="2" face="Verdana, Helvetica, sans-serif">Thats what I did, Works great &amp; easy to remove.
          There's a hole in the side of the bracket for the afore mentioned screw. It's part of the OEM design. I use 1" hex head sheet metal screws.
            <font size="2" face="Verdana, Helvetica, sans-serif">Yep, King, Old School, and Dutch are absolutely right. That is the best way to secure start pad.
              screw in odd side have to agree works really well and easy to remove
                I should have been more clear. I glue the starter pad with contact cement. I do also use a sheet metal screw in the bottom of the pad.
                You know when you have to repace the starter pad the contact cement is really not that bad to get off of there. There is some clean up but the glue does hold better than just a screw for me.
                  I've never had a problem with the screw alone but contact cement sounds like a good choice if it is still trying to climb out of the bracket.
                    I looked both sides over for a hole, not present [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img]
                    BUT [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] Have drill! will make hole [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                    Thanks a bunch [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img]
                    Just hit reset.
                      Some older brackets never had holes drilled in them. I used to glue and screw them in because when the first urethane came out they wouldn’t stay in to well.
