The owner of the 12 lane house that I work will not use 5 inch pulleys and I agree. With Stahl's over the top turn pins, we seldom have pile-up's with 6 inch pulleys. we also use two and a half instead of three and a half to drive the carpet and humpbacks. Far less wear and the ball is back in time for the fast rack's. Also less underlanes with the Shur-stucks.
6 inch pw pulleys
Re: 6 inch pw pulleys
We didn't have much luck at 6.0 pulleys....but agree with the slower backend pulley, we used a 2.25" for our humpback returns as well.....Peanut
Originally posted by Dutch:
Where can I get the smaller A112/A114 pulleys? Got a # ?
What size and type of pulley did you want? There are a lot of options at <a href="http://www.grainger.com" target="_blank"><a href="http://www.grainger.com" target="_blank"><a href="http://www.grainger.com" target="_blank"><a href="http://www.grainger.com" target="_blank"><a href="http://www.grainger.com" target="_blank"><a href="http://www.grainger.com" target="_blank"><a href="http://www.grainger.com" target="_blank"><a href="http://www.grainger.com" target="_blank"><a href="http://www.grainger.com" target="_blank">http://www.grainger.com</a></a></a></a></a></a></a></a></a>
The cast iron fixed bore sheaves for 2” to 4 inches range from $7-$15. The die-cast are about 1/4th the cost of the cast iron.
Triac
Has any one else had problems using the 5 inch pulleys with the B190 belts? Can't get any tension when using this belt. Works great with a B188.
Where can I get the B188 belt. AMF and JCP only have the B190.
MikeMike
Mike"Where are we going, and why are we in a hand basket?"
B-188; optibelt-VB S=C plus, Made in U.K.
Translation Required [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
