Omegatek Problem 1
Omegatek Problem 1
Table at 355, sweep at 270, fingers closed, 1st ball light and strike light on. Also, pinspotter jumps back to 2nd ball after spotting new set of pins. Replaced TA1 & SA switches. Other boards working fine. Sent back to Murrey, they returned and said nothing wrong with board.Tags: None
Re: Omegatek Problem 1
You stated you changed TA1 and SA. If you are having problems with the switches, save yourself the hassle and change all 3 for both the table or sweep. But before you change both of them, you can spray a solvent in there such as WD-40 to try to clean the switches up. SA and TA2 are repsonible for changing cycles when the table and sweep are going up. Also try disconnecting your OS switch, as it can be used to change cycles as well.
I'd recommend something like CAIG DeoxIT D5, ECG Electronics Wash, ECG Delicate Parts Cleaner, or a quality brand of motor/contact cleaner that's safe for rubber and plastic. Compounds like these will remove the gunk, and evaporate cleanly.
Also, your best bet is to change out the switches... they don't have too much in the way of open areas to get a spray cleaner into, so it's not guaranteed that spraying them off will help. If the plunger is sticking, it'll probably work, but if the contacts are carboned or gunked up, it probably won't have much effect.<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
