Omegatek Problem 1
Omegatek Problem 1
Table at 355, sweep at 270, fingers closed, 1st ball light and strike light on. Also, pinspotter jumps back to 2nd ball after spotting new set of pins. Replaced TA1 & SA switches. Other boards working fine. Sent back to Murrey, they returned and said nothing wrong with board.Tags: None
Re: Omegatek Problem 1
Did you put it into another chassis on another lane and get the same problem?TSM & TSM Training Development
Just to clarify... you say that the chassis is at electrical zero (355), and the sweep is at 270 (2nd guard)... The problem is NOT (?) moving with the chassis... it's staying on the same machine. Do I have that right, or is the problem moving to another lane with the boards/chassis?
If it's staying on that particular lane, I would take a close look at the camswitches and the cam settings... especially the sweep switches. Go through your cam checks with the go/no-go gauge first, then run it. If the problem appears again, change out the 6 switches (sweep and table) go through the checks again, and run it. Flaky switches can cause problems like that... and many times, the problem is intermittent.<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
