table drive eccentric
  • table drive eccentric
    Anyone here ever had such problems with the different springs near the table drive eccentric?
    Last week we had a problem with machine 8. The 1st to 2nd cycle the table didnt stop at pinhead position. The table fell on the pins heads with the cups.
    We immediately saw the problem: the spring pin was broken in the arm latch.
    After replacing this, the next problem arrived:
    The compression spring that makes the latch fall in the sleeve was lost. A new one had too less compression so I pulled it a little longer. The next problem was the latch didn't pop up anymore beacause of the strong force of the compression spring. When I watches carefully to the eccentric/ spotting solenoid I saw the spring under the solenoid totally compressed when making a 2nd to 1st cycle. Didn't saw this on other machines. After repacing/stretching this spring the machine finally worked correctly.
    Isn't it stupid that these machine are really depending on this stupid spring tensions? I really amsaze myself about this we work on such old mechanical stuff.
    greetings from Willem, mthe Netherlands
    Re: table drive eccentric
    My only real complaint about the solenoids is how long they take to replace when the roll pin wont budge. Yknow, the teeny tiny roll pin that makes removing them so easy? When it wont budge , the solenoid can be a pain in the ass when youre in a hurry.
      I always keep a spare soleniod assembly and a spare eccentric assembly on hand, they take only minutes to change, and it is much easier to change parts in the vice
        You can slide the table drive to close to the Shuttle Bracket Casting and it will rub on the Cam Link which will makes it seem that spring pressure is the problem.
        Slide your Table Drive out 1/8" and all should be well.
          If the spring is too short.....the pin goung through the table drive has the holes egged out where the roll pins secure it at each end.....just had one do this a few weeks ago.
