Howdy guys.
Recently had a lane where the OS switch was out of adjustment because of a bent bolt. No matter which way I went, I couldnt get the switch to operate properly. And of course I didnt have the proper replacement bolt. So I took a bolt thats used to hold the pin holder to the shuttle and ground the end down to fit in. However upon doing that, the bolt depress the button on the microswitch. So now my fix was to use a microswitch that is used on the Bin switch with a bigger button. I was able to get the bolt to adjust properly with the new microswitch. Now the OS switch operates fine with no problems.
Wang
Wang
