Carry
Carry
Id like to hear some general formualas you guys use to help pin carry. Combinations of things like panels and pitching the pindecks, new pins and flatgutters. Maybe even oil patterns. What do you think gives you the carry or lack of carry in your particular houses?The impossible often has a kind of integrity to it which the merely improbable lacks.Tags: None
Re: Carry
Make your flat gutters solid. Be sure your pindecks are tilted up around .170 inches. Remember the limit is .187TSM & TSM Training Development
Re: Carry
Seeing you have 70's, you have an inferior kickback, compared to an A model Brunswick.So you really need to make sure everything is tight.What you need to check is all the screws and bolts holding the machine and channels on top of the kickbacks are tight,probably machines strapped together to stop all that sway when you walk across catwalks if not already done would also help tighten kickbacks, toe screws in the bottom of kickback are tight,flat gutters all screws holding the edge boards and the fibre strips are tight as well as making sure the flat gutters need to be hammered into place (Don't Even Think About Plastic Flat Gutters,they can kill scoring ).All this as well as ensuring pindeck is raised at back with a 30 thou tilt up on 10 pin side as most people are righthanded.
willey.always doing my best.
Re: Carry
The reason I don't like plastic flat gutters is they can't lock in the kickbacks tight enough.By that I mean with really tight flat gutters against the kickbacks they become one piece and add to the rebound effect.If you know old Brunswick A kickbacks you will notice that the kickback finishes at the back of the machine,where the AMF and A,2 kickback finishes just behind the pindeck,to me this is where the kickback needs to be solid not floating.As a bowler I have always found the A's to be the better scoring centers with noticeble pin action,in fact we have just replaced our 40 year old kickbacks with incredible results,with a reported 300 game where the pin flew across the deck in front of the still standing 5 pin and rebounded off the other kickback to take out the 5 pin.
Now I have used the plastic flat gutters before in a 70 center and the lack of kickback was noticeable,as for plastic kickbacks we have those on our Brunswick kickbacks with no problems.
Re: Carry
just do what we do
tell them tuff the main reasion we oil las\nes is to prevent brake downs
good pins or bad pins tell the bowler to learn how to bowl and stop blameing the lanes
or give the bowler the run around
talt to the head tech
then he will say talk to u
u can actually train a bowler
(good luck u got a lot of work ahead of u)
[img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img]
