Please correct the following statements as to there validity. Need you experts opinion.
1. On a 82/70 solid state chassis with 5 cards in place when the sweep is at gaurd position TA2 informs the sweep, yep, its clear to run, and the sweep will run across the pindeck. Back at gaurd position TA1 will initiate the sweep to run to home. ??
2. On single conversion boards before 1984 TA1 was used to lift the sweep from 2nd gaurd to home, leaving the table slightly exposed. After 1984 TA2 was used to run the sweep home. (omega-tek single conversion board)
3. Was there a pinspotter that used TA1 to run the sweep home from 2nd gaurd? if so what model?
4. In theory TA1 and TA2 must both be open to let the sweep run from 2nd gaurd to home.
