Okay, there is an avatar i would like to use, but i do not know how to add it to the ones on bowltech or to use it.. can yall help me figure this out with clear easy instructions... thanks
avatar
Re: avatar
The ones on BT are 'canned' on the site and cannot be changed. You may use a 'non-BT' avatar (like the one on the left), but you will have to host it out on the web somewhere, and then link to it in the "my profile" screen on BT. The Bowltech server doesn't store avatar images other than the ones it already has.
If you need some filespace, there are several free servers that allow outside links... some guys on here use them, and could probably give you an idea of which ones. Unfortunately, many of them (geocities, angelfire, homestead, etc...) do not allow linking files to other "offsite" areas.
If you can't seem to find one, I can probably host your image off of my site for ya for a while.<span style="font-style: italic">Educatio est omnium efficacissima forma rebellionis</span>
