table problems
table problems
we're running 82-70s with MPS. im having a problem with lane 6. it's happened to me 5 times. the table will just stop in the middle of spotting, or sometimes it will stop just as it is about to finish re-spotting at about 300 degrees. i changed the chasis and it still does it. when i get the call, i just hit the table relay and it finishes to home. when it stops during spotting, the sweep will finish normally. and the table is still down. any ideas???- JasonTags: None
Re: table problems
1 - check table cam cluster, make sure it hasnt migrated to where the cams are no longer hitting the levers.
2 - check C1 plug. next time it does it try jiggling C1 to see if that makes table move.
3 - but you say you just hit the table relay and its fine, sounds like table relays on both chassis need replaced.
Re: table problems
the way we test our chasis coils on the sweep & table we activate the cam switch and see if the realy is pulling in
just an ideaRespect is not given freely
it must be <span style="font-weight: bold">EARNED </span>
Re: table problems
How old are your MP chassis? The older ones didn't have a capacitor in the BS circuit. Unlike the SS chassis where the SP relay keeps the circuit closed, the MP's are susceptible to stopping as soon as the BS opens.
It's just a small 100mf disk capacitor. You can put it in the chassis or in the wireway. I'd have to do some research to remember exactly where it goes in either application. It's been a while.
Re: table problems
Also check for bad backend CB as this is wired into the Spot circuit."Where are we going, and why are we in a hand basket?"
Re: table problems
Dutch
My schematic shows that the small cap needs to go over terminals strip #s 32 and 34. + end on 34 which is the common end of the switch and the - end goes on 32 which is the N.C end of the switch.
Hope this helps.
wang
