82-90 Sweep mounting brackets
Tech of the Year 2004,2008
- Jun 1999
- 4204
- A- 2 / 8270
- Qubica / Frameworx
- Phonix-S / Kustodian
- Prolane / HPL / SPL
- 1983
Re: 82-90 Sweep mounting brackets
No they ae not stronger, but fewer parts. We are just about finished our 42 lanes...
I like them, smooth and less deadwood.....Peanut
Member
- Aug 1999
- 2547
- A-2s, GS-X, 82/70-90
- Brunswick Vector Plus HD
- Brunswick Envoy
- Pro-Anvil
- 1985
I've had them on for at least 3 years now with no problems. One note, they do bend if the sweep gets hit hard enough causing the sweep to "hop" at the 4-5-6 line coming back to 270. Easily bends back though."Where are we going, and why are we in a hand basket?"
Just a quick note about the new sweep mounting brkts. I've been getting mine from Stahl's and they are of a beefier material than the ones you get from AMF. It has the same part number as the AMF ones. I just tell them that I want the heavy duity ones
AMF DOCTOR
The doctor makes house calls
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
