sweep w/not cycle
sweep w/not cycle
Have a problem with 82-70, with single board XOP chassis and Qubica Scoring. The problem started BE coming on but sweep would not work. Checked cam switches and they are good, looked at wiring at the master switch box and all seems good, swapped chassis with another machine and the chassis works great on the other machine and the original machine still has the same problem. after the chassis swap the machine statred to cycle all by itsself and would not stop. almost as soon as it started to non-stop cycle it stoped and now the sweep will do nothing!!!! Any suggestions???Say what you mean and mean what you say!Tags: None
Re: sweep w/not cycle
Did you check the sweep motor reset? Check the plug to the motor also.I might not be as good as I once was, but I'm as good once as I was ever was. http://www.bowltech.com/forums/impor...2012/smile.gif
Check the sweep in the zero position and see if it's make'en that switch. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
The sweep will not run if the sweep is not high enough to make this switch.
You can tie the two wires together to bypass the switch. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]
Also, might give you a cushion sw failure.. [img]/content/btubb/images/%%GRAEMLIN_URL%%/wink.gif[/img]If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
oggyd2; Was it the mask plug [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
