lane 2, table motor will not start, i clean up the switch cards and test windings ETC, put it bacl together and it will not start, i think 'thats odd' and take it apart again (AO smith combi) and everything is fine, i pull the lead out of the table motor and plug it into the sweep motor and it runs perfectly, started and stopped 20 times with no problems, plugged the lead back into the table and it wouldnt start, i got my newly rewound/refurbished combi and install it, it dosent start, i think 'sh1t, my new motor dosent run' and plug the lead back into the sweep motor, works perfectly, so as something to do whilst i mulled said probelm over, i swapped both combi's (table to sweep, sweep to table) now to my astonishment, the table motor would not run but the sweep motor would, so i knew both motors to be good . . . .
10 points awarded for the first person that works out what the fault was!
even with a degree in engineering, some things still catch you out from time to time!
