Is the amf ball detector 244 001 058 compatible with the above equipment. The ball detector is for a pair of lanes or am i wrong ?
82-70 and ball detector
We have 82-70's with accuscore plus.
Is the amf ball detector 244 001 058 compatible with the above equipment. The ball detector is for a pair of lanes or am i wrong ?Tags: None
Re: 82-70 and ball detector
Thanks astro, I thought as much. We are pleased with the results, currently we have it on half our lanes.
I was asking because because we were given a price 30% higher than the list price. I can't understand why. So I ordered the above part, now one of the bosses (who incidentally wouldn't know the difference between a pin and a bowling ball) has told me I've made a costly mistake.
Making a mistake didn't worry me, it's them being right for once that did !
Originally posted by lafarge:
hmmmm. where are your ball detects located just wondering because of some problems I've come across with the amf ball detect."Where are we going, and why are we in a hand basket?"
We put ours directly under the masking unit. We made our own deflector bracket to sit infront of it. Any stray balls bounce straight off it. Incidentally we've never had a problem once with any of our units. They've been in a good few years now.....
hmmmm. and Kat I had a center in pheonix that we had amf ball detects and they were mounted to the kickbacks the only problem was that when someone threw a good strike the pins would hit the kickbacks sohard the would vibrate the kickback enough to cause the other machine to cycle. JBEEs helped me to install them to the concrete below the kickbacks with a wood bracket so they could't make contact wi the kickbacks. after that they seemed to work ok. Do like the steltronics bal;l detects they work well as long as the bumpers don't interfere with the beam or block the reflectors like was goingon here from a bad bumper install.They say that the **** rolls down hill but the smell always starts at the top.
