NEED IDEAS NOW
  • NEED IDEAS NOW
    82-70'S WITH 5-BOARD CHASSIS. Last night (first night of league) had a machine that wouldnt run (#14). Pin light flickers, Back end motor contacts on chassis was chattering & arcing. Pulled chassis & replace with a known good one. Nothing happens, While checking all wiring I notice smoke coming from chassis. Transformer is smoking. After alot of searching I find out the breaker in the main panel is fry'd. I replace it with a good one. But still nothing at the machine. Today had a electrction come out as I noticed some other breakers didnt look good. He replaced 2 and left. 15 minutes later I smell smoke. Finally find that it's the transformer on lane (#13) smoking & it's not turned on. So far I have fry'd 3 transformers. Any & all help please
    Re: NEED IDEAS NOW
    Being that you have already changed the breakers, and it is not isolated to a single machine, I would hazard a guess that your problem is in building wiring. That might explain the fried breakers in the 1st place. possible the wire is old, or not sufficient for the amperage draw. Might need to call Mr. electrician back in to check that out.
      Re: NEED IDEAS NOW
      I have 110 to the machines. I replaced all 3 transformers. But have not put them on any machines yet. I know part of the problem is that the power is comming into the building at the front. The main and all breakers are clear up front front too. Then they run to the back.
        Re: NEED IDEAS NOW
        Sounds like possibly the neutral leg has dropped in your main panel and everything is trying to run through the ground wire. The transformers serve 2 purposes. It steps voltage down to a workable level, plus it isolates the high voltage from your side. Just a thought. Definately call an electrician. I agree with MR. JIMDORSIN.
        SGT
        U.S. Army/AVN
        Retired
          Re: NEED IDEAS NOW
          Call the electrician! [img]/content/btubb/images/%%GRAEMLIN_URL%%/eek.gif[/img]
            Re: NEED IDEAS NOW
            Thanks guys
            I finally figured it out.
            I cant believe I can be sooooooooo stupid.
            Must be post season stress
              Re: NEED IDEAS NOW
              I had a neutral leg come loose once...fried the T-2 transformer in all the even machines...yuk!
                Re: NEED IDEAS NOW
                Originally posted by old-school-mechanic:
                Thanks guys
                <font size="2" face="Verdana, Helvetica, sans-serif">Well????? Do tell
                  Re: NEED IDEAS NOW
                  3-phase comming into building. When I found the fry'd breaker the leg it run off of was fry'd too. The leg above it was clean, So I hooked the new breaker to it. When electrician come in. He did the same thing. They was all hooked to the wild leg of the 3-phase. It carry's about 190 volts. Dummy me, I just tryed a light tester. I didnt use a meter to check. Electrician was a young guy, just started working for his dad. I did the meter soon after my last post. Knew right away what I did. (STUUUUPPIIDD)
                    Re: NEED IDEAS NOW
                    That'll learn ya... [img]/content/btubb/images/%%GRAEMLIN_URL%%/smile.gif[/img] That 'delta' leg of 3-phase is something to stay away from if you're not familiar with triphase panels. Good thing it didn't do worse damage.
                    Anyway, glad ya found the problem...
                      Re: NEED IDEAS NOW
                      Being a spark myself, i would get it checked out, one thing a lot of places fail to do is balance the load, ie roughly the same current draw on each phase. When I started at my place all the machines were on one phase the lighting on another, totally different loads. Lot better now.
                      How old is the wiring and when did you last have a proper test and inspection.
                      kev
                      If Wile E coyote has enough money to by all that Acme crap why doesnt he buy his dinner?
                        Re: NEED IDEAS NOW
                        <font size="2" face="Verdana, Helvetica, sans-serif">Bingo.
                        Late, but what the he-double-hockey-sticks.
