Spotting problem
Spotting problem
82-70's. The machine cycles fine for the first ball. When it goes to sweep the deck after the second ball, as the sweep reaches the back of the pin deck the table sets a rack on top of the sweep. I have changed chassis, replaced a couple of bad pins in the c1 & c2. I checked and adjusted all the sweep and table cam switches, but to no avail. The only thing that I can think of is that I maybe have a bad sweep cam switch. I will check that Tommorow. Any other ideas or suggestions would be helpfull.SGT
U.S. Army/AVN
RetiredTags: None
Re: Spotting problem
make sure something hasent fallen into the wireway that my be shorting out some of the terminal strips....had that throw me in vermont, took a week to find the micro wire hair that was causing the sweep to (randomly due to its small size) stop at the 4 5 6 line about every 15 frames....didnt see it until i accidently hit it with the flashlight beam enough to get a reflection, it was that small...
The problem you are describing is common of over adjusting by using the lever screw to fine tune stop positions. As such, it also throws the secondary functions of the cams "off" a little."Where are we going, and why are we in a hand basket?"
Right. If SC N.C. malfunctions (closes)after the sweep goes to zero, then at the next cycle it will begin a run-through after the time delay and meet the table at the tail plank.
