BIN: Pin guides
  • BIN: Pin guides
    This would certainly make changing several parts on the bin a little easier, and a lot less time consuming. Definitely a back saver!!! The holes don't have to be this big, but I took the measurements off an installed bin assembly; not an easy chore.
    Parts suppliers: Get your vendors to re-tool and make our jobs easier, so we can spend more time up front playing pin ball, drinking coffee, (or beer), and telling the bowlers everything they need to know about bowling. Right T.C. LOL
    Re: BIN: Pin guides
    I've taken most of those things off. Especially the ones that get in the way of other hardware. I use them for up-rights on the 4 & 6 bins.
      Re: BIN: Pin guides
      Less time consuming? A little
      Less back breaking? Not!! your still on your knees (haha) & bending over on the catwalk but nice Idea. [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img] Not to be skeptic, but figure a way to change shock mounts in 2 & 3 bin assb'y, I'll be impressed LOL. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
      SIM
      If its SIMS, its only a game.
      Just hit reset.
        Re: BIN: Pin guides
        <font size="2" face="Verdana, Helvetica, sans-serif">Dutch,
        Post a pic for me. tks
        Ken
          Re: BIN: Pin guides
          Mine are in the trash.....useless.
            Re: BIN: Pin guides
            I've also taken all mine off...all they do is cause problems.
              Re: BIN: Pin guides
              Thanks for your input guys. Will have to give that a try. Never really paid any attention to what those puppies do or don't do. Just know they are a pain if you have to change other things out.
                Re: BIN: Pin guides
                I've never had a problem getting under them.
                Just ground a cheap 7/16" boxed end thin enough to slip between the guide and stringer.
                -- Larry
                  Re: BIN: Pin guides
                  I'm with Dutch. I've removed all of mine and flipped them up and at an angle towards the front on the 2-3-4-5-6 positions to eliminate the neck from hanging over the stringers into adjacent bins (causing the occaional pile-up).
                    Re: BIN: Pin guides
                    Less back breaking? Not!! your still on your knees (haha) &amp; bending over on the catwalk but nice Idea. [img]/content/btubb/images/%%GRAEMLIN_URL%%/cool.gif[/img] Not to be skeptic, but figure a way to change shock mounts in 2 &amp; 3 bin assb'y, I'll be impressed LOL. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
                    SIM
                    <font size="2" face="Verdana, Helvetica, sans-serif">Since everyone has removed their pin guides maybe this will help with shock mounts in 2&amp;3 bins.
                      Re: BIN: Pin guides
                      Careful on that headpin chute. It looks good, but be sure that the cuts are filed smooth. The head of the pin usually slides down on the painted part.
                      As far as the pin guides go, if your second stack of pins get deposited straight every time (no hangovers), then the guides do nothing. But they do a good job of turning the upper pin in straight when its on an angle.
                      I've removed all the 5-pin ones, plus the other 4 inner ones. Found the outer ones still help, and they don't interfere as much as the inners on other parts.
                        Re: BIN: Pin guides
                        Here is a pic of the "BatWings"
                        "Batwings" extenders
                        Peanut
                          Re: BIN: Pin guides
                          Thanks BowlEquip and Peanut for the info..
                            Re: BIN: Pin guides
                            Thanks for posting the pic, Nut. I knew someone had it. Just couldn't remember who.
                              Re: BIN: Pin guides
                              Masternut, looks like a good idea, I did see something not mentioned in the pics, it looks ( a bit dark ) like something modified on the front of the 9 and 10 bins, I can't see any mention of this in any of the pics.
                              willey.
                              always doing my best.
