Lazy Spotting
Lazy Spotting
Ok guys, this one's got me stumped. I have one machine that the spotting cups will tilt late causing the pins to all be off spot to the front and occasionally fall over. The kicker is, if there is only ten pins in the bin, the machine will spot perfect. If the bowler gets say an 8 or 9 count and there are double pins in the bins, the cups will tilt late. Any ideas?Give me a hammer and some duct tape and I can fix it!Tags: None
Re: Lazy Spotting
For the last 24 hrs I've been trying to figure out how double stacked pin could cause what you're describing. All I can come up with is that the pins might sit in the cups differently.
See if the pins might be catching on something. Maybe the 1-2-4-7 wireway is bent & the 4 is catching on the table plug bracket?
Re: Lazy Spotting
Dutch, you're not the only one trying to figure out what is causing this. I don't have table wiring so there is no plug, but that is a good thought. I did get the machine to spot the pins "ok" by adding tension to the yoke springs.
This however is causing the cups to snap open after spotting which i know means too much tension. I will readjust the springs after I figure out what is actually causing the problem. I think I'm going to give Carl a call on Monday and pick his brain.Give me a hammer and some duct tape and I can fix it!
Re: Lazy Spotting
Paul, That is also a good idea. But here is what solved the problem. I adjusted the table springs back where they should be to stop the cup "Snap". Then I moved the shuttle front by shortening the connecting rod. I'm not sure why I thought to do this but it solved the problem and the machine spots perfectly every time. Now I just hope I don' start having double shuttle problems on this machine. Thanks to everyone who racked their brains on this one.Give me a hammer and some duct tape and I can fix it!
Re: Lazy Spotting
Members
- Feb 2004
- 850
- 82/30,82/70,82/90,XL,XLI
- AMF and Qubica
- Various
- wood and synthetic
- 1953
Re: Lazy Spotting
I think you will find that the hanger behind the spotting spring is elongated and the bolt also.This is connected to the spotting lever and you may have turned it during the shuttle movement.
Check it out if you like.Good luck.
Laurie
Scotland.
Re: Lazy Spotting
I am glad you found the problem. It doesn't make any sence to me why the shuttle would fix your problem. Anyone???
Remember the K.I.S.S. Principle.
(Keep It Simple Stupid
The only thing I can think of is maybe the jam nut at the front rod end on the connecting rod assy is loose...very easy to overlook if your not specifically looking for it. The other, maybe, loose jam nut on the bolt that the stop lever rests against as to not let the connecting rod/lever cam follower "go into" the dwell on the shuttle cam on a first ball cycle...in other words, the bolt head is too tight against the stop lever.
Re: Lazy Spotting
Update: After I moved the shuttle front, the next night had all kinds of double shuttle problems. So I put it back where it was, and watched the pins very closly as they fell into the cups. I found that the pins were actually "hanging up" on the pins on top and falling into the cups later than they should be. As of now I have not done anything to correct because these pins will be coming out next week and I want to see if different pins have the same problem.Give me a hammer and some duct tape and I can fix it!
Re: Lazy Spotting
Use a hammer and some duct tape [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
LaurieSo it goes.
Re: Lazy Spotting
Do what Tall Paul said 7 days ago, and remove the two spotting cup liners, but leave the top one in.
Worn LBS Rudder Cams
Back after 10 years with my mini lane
Hey guys! After building my lane 10 years ago I had to relocate for work and could not take my lane. It has been in storage ever since. I finally was able to bring it down...
The AMF dude
Transformer smokes
I hava a tarnsformer that started smokeing. I replaced the transformer and it runs a few seconds and starts to smoke again. Any Ideas?...
Turret 1-7-10 problem
