90's Combo gear box & shaft.
  • 90's Combo gear box & shaft.
    When we rebuilt our gear boxes in our Korean package, had about 10 boxes off the table that had multiple teeth missing. Guess it was from all that pin jamming, shuttle lifting, deck banging and no telling what else went on with these machines. This particular gear had 4 teeth missing so we didn't use this in the rebuild. The gears with 3 or less we rebuilt and put them on the sweep ONLY. We marked the outside with a marks alot and turned the rotor and installed the sweep motor where the broked teeth would have no pressure i.e. climbing or falling to 66%. Have been running them over 2 years with no trounble.
    Had 2 rotor shafts to sever where the rotor goes into the gearbox. Anyone know what caused this????
    They look like they had been cut with a laser.
Worn LBS Rudder Cams
Back after 10 years with my mini lane
Hey guys! After building my lane 10 years ago I had to relocate for work and could not take my lane. It has been in storage ever since. I finally was able to bring it down...
The AMF dude
Transformer smokes
I hava a tarnsformer that started smokeing. I replaced the transformer and it runs a few seconds and starts to smoke again. Any Ideas?...
Turret 1-7-10 problem
