Occassionally this lane will not complete a shortened strike cycle. This is what happens,
The scoring will record a strike on grid and expander board will also read strike as no led's lit.
Sweep comes down and sweeps through pin deck, returns to 270 and stops. The table will then feel for pins, Ie, the spot solonoid doesn,t engauge, and the sweep will return to zero with table up and fingers closed.
Things that have been done.
- Swopped out chassis to see if boards at fault / relays. Nope.
- Checked C1 pins for damage. ( 3 connected for spot solonoid) All ok.
- Used C2A tester to test all switches on machine. Found no connection from TA1 open to chassis. Fixed that but still problem continued.
- Changed out table cam unit. Nope
- Checked for grounds in mask unit wiring. None I could see.
Have probably overlooked something simple. Problem seems to be on machine side. How can I jump the elco plug on the chassis? Believe it is terminals 25 and 26 on the plug. But when joined together machine wouldn't run. (when jumping 5+6 on A+MC plug)
Any thoughts most welcome!
PS. Strike light doesn't come on when this fault occurs and no 2nd ball light either.
