When the resin reactive balls came out, we started having balls under cushion on all 40 of our (30's) machines. It didn't occur on strikes, just spare shooting. The ball would come under the cushion like an egg shooting out a chickens @ss. We changed bounce plates, jacked up the rear of B.P., changed brackets, vibration dampners, cushions until we nearly went nuts. Nothing worked, as they kept comming under. Finally we lowered the cushion. First, we made this shock to move the bottom of the cushion about 1 @ 1/2" forward.
Next we reversed the blocks in the boxes to lower the cushion. This box would go on the B.D.S of a L.H. (even number) machine; O.B.D.S in an odd machine.
This stopped our problem but the weight of the cushion soon wore the small bit of rubber at the bottom of the box. The box edge started to cut through the weldment shaft an inch from the end. So we drilled a 3/8" hole in the bottom of the box and block and inserted a front roller bolt with locknut to support the weight. This bolt also wore the weldment but not as bad as the other.
If your truck blue book price rises or falls in porpotion to the amount of gas in tank, you could be a red neck. LOL
