What might cause this
  • What might cause this
    One of my machines is having an odd problem.
    This machine will not cycle at all. For diagnostic purposes I removed the Omega Tek board and put in a set of five boards. I wanted to see what the lights on the one board were doing. Guess what? No lights, not even the bin switch. The table can be run from the TA switch. The sweep will run from the sweep run switch on the BE control box, however will not run to zero degrees after passing 270 degrees and will not run at all from the SA switch. Lastly, I can't get the machine to change from second to first ball cycles.
    I switched chassis with another machine and the problem didn't move. Turning off the scoring ysstem didn't do anything either. Is this a cam switch problem? An idea of where to start would be nice.
    To err is human but to really mess things up requires a college student.
    Re: What might cause this
    Check the OOR switch and circuit and make sure nothing is grounded.
    Wang
      I am assuming the pit lite is on! NO lights on the PC-1 at all? It might be a PC-1 with optocouplers instead of neon bulbs. Sounds like it might be in instructomat. Do you guys still have the managers control (original Frame-O-Meters) hooked up? Might want to make sure some smart arse hasn't put the switch in instructomat up front! Also take a look in the A&MC box too for a problem... Lettuce no..
        Instro would be my first thought too, however, I am not fimilar with the actual 5 boards, every SS I had was Omeg-tek fited with the boards long gone.
          sorry double post (was at the proshop....ssssllllloooowwww computer)
            Not sure about Instructomat, either... usually the contactors will chatter and spark like crazy if you run the sweep while in Instructomat.
              Did you try a new CB on the rear control box? No #1 board lights or flickering lights is usually the CB.
              Rep. Rob Bishop (R-UT)
                Old managers control has been disconnected. The desk dummies liked to play with the switches. Also night security liked to come in and bowl, not a good idea with the scoring system turned off and the table cable unplugged. Will try replacing the breaker and see what happens.
                  Ck the C-1 plug make sure you dont have any burnt or loose connections. or perhaps a cracked block I had c-1 block crack and gave me the problem you were discribing took me a day to figure c-1 was at fault..if the oor was at fault you would still see lights in the board the os light would be lit up. if the omega logic card was at fault the machine would run normal..
                    You didn't mention if your backend was coming on or not. If you have a masking unit switch I would try there.
                      Any grounding of the managers control loop will result in instructomat. Check every plug, including the A&amp;MC for possible grounding. Also, if the managers control boxes were disconnected, see if anf of the wires, is still running into the back overhead, could be cut or grounded. If disconnected at the A&amp;MC boxes, disregard. If disconnected at the 8-lane distribution boxes, check the wires from there to the A&amp;MC boxes also.
                        Music Man, AmfPinboy has got it, no low voltage means the CB on the back panel has gone, a common problem.
                        willey.
                        always doing my best.
                          Its probally the CB but you can also try an A&amp;MC jumper at the machine to eliminate any grounded wires from the old managers control. That CB will cause some funky problems.
                            For your main problem, my moneys on a short in the shadow ball circuit. The easiest solution to isolate a ground from instruct-o-mat is to pull the little grey wire (and tape it off) from the T2 transformer. This takes a few seconds and will remove any doubt that the machine is in shadow.
                            Two other things (off the top of my head) that might cause some of your problems is the circuit breaker in the mechanics control box and the normally open contacts of the SA switch.
                            Triac
                              Are the ball/cycle lights working?
                              By the sounds of it, the manager control circuit is working because you have contactor power. The question is have you got board power supply.
                              I assume the CB contacts are actually working - they cut power to the manager control circuit on our machines (but there may be variations to this - I have a wiring diagram that shows it in the 110V T1 primary circuit). You'll know just by switching the CB on and off - you'll hear the M relays clicking.
                              Faulty wiring going to the CB (in the BE control box) can cause the -150VDC supply to fail, meaning the board would have power (and you'll have ball lights), but you won't have any input to the machine (so no cycle, no cycle step, no SA sweep run, etc). You would still have SWS sweep run, and TA1 table run (because they do not go through the boards). This sounds like your problem, but this would only affect the 5-board setup, not the omega-tek.
                              Is there any difference in symptoms at all between the omega-tek and the 5-board?
                              When you swapped chassis, did you keep everything in the chassis, or did you put some stuff back in the original machine (boards, relays, etc) - I just want to double-check that this is a machine fault and not something in the chassis.
                              Andrew.
