Purpose of removing belt runner on dizzy?
  • Purpose of removing belt runner on dizzy?
    Why do you remove belt runner?
    Re: Purpose of removing belt runner on dizzy?
    The pin will not roll off the distributor.
    It is like raising the banks of a river.....the pin will stay between the sides.
    It works.
      rather than the pin rolling out of pin wheel over the belt onto other side and either falling off, or stalling causing next pin to be too close. . .pin rolls off the pinwheel, drops like a rock and up it goes.
          Not exactly clear.
          Picures possible please?
          Thanx,
          Fatty
            Couldn't the pins possibly get jammed under the belt or between the belt and guides if the belt runner was removed? Are there certain belts this would work better on than others? Is this a matter of simply removing the runner requiring nothing else and you are good to go? Isn't removing the runner not really fixing the problem?
              Originally posted by peapodd@mindspring.com:
              Not exactly clear.
              Thanx,
              Fatty
              <font size="2" face="Verdana, Helvetica, sans-serif">What center do you work at?
              I work at Centennial in longmont.
              Mike
              Mike
                Originally posted by TABLEJAM: Couldn't the pins possibly get jammed under the belt or between the belt and guides if the belt runner was removed? NO Are there certain belts this would work better on than others?Vantage Is this a matter of simply removing the runner requiring nothing else and you are good to go? Yes Isn't removing the runner not really fixing the problem?It does fix many problems
                  <font size="2" face="Verdana, Helvetica, sans-serif">From my experience the only thing this mod will help is pins rolling off the distributor. But usually adjusting the Kidney pan and o-pan will eliminate that problem as well.
                  But have found that it's best to use a thicker belt. The thin belts seem to stretch. As far as pins getting under the belt, this will only happen if a jam happens. Under normal operation they should not get under the belt. I have done this mod to 5 of 32 machines and don't see any reason to do the rest. I also rebuild the distributors ever 2 years, this alone will help get arid of all the problems.
                  Mike
                  Mike
                    Yes Pins Can Get Jammed Under The Belt, It Has Happened To Me. Kidney And Orientation Pan Best
                    Adjustments.
                      Just from seeing other machines and how their orientation is set, you can see why pins flip off the sides of the dist. I try and set my rails so the pin rolls into the pan and makes the turn without excessive snap. In all honesty even though I set my rails for little pressure on the pins, I still have put pin stabilizers on both sides of the dist and I leave the belt runner in. You can make your own for about $1 or by ready made ones from Stahl's. If you watch the pin as it makes its turn on the sides of the pan, you'll notice that the pin never touches the belt till it's almost turned. Why loose making contact with the belt even harder by pulling out the runner. Just one other idea, take two of Vantage's belt risers and screw them together, counter sink the flat head screws, and put it under the belt. The pin is now in cintact with the belt as it makes its turn.
                      AMF DOCTOR
                      The doctor makes house calls.
                      AMF DOCTOR
                        [img]http://pic17.****************/VOL856/934456/1718790/23196389.jpg[/img]
                        So it goes.
                          This is one of the best mods we have ever tried.Pin jams are down to nothing.We have different belts running thick &amp; thin no problems.It keeps the belt low which in turn helps the pin "roll" better off the pan and line up on the belt.It gives the pin a "valley"!GREAT IDEA!!!
                            It works good for us. I use a thick rough top belt that works better with the belt runner out. It does cause the thinner belts to stretch faster.
                            Pete
