Elevator
Tech of the Year 2013
- Jan 2003
- 13208
- AMF 82/70SS/OT/EXP & MP
- ConP/3QT/QVis/FBOX -BOSS
- Summit S/Flex Walker
- AMF HPL & AMF Integra
- 1986
Elevator
Ok, there's a LH and RH pin elevator for the respective machines. There are pin holding brackets in the pinwheel for each, LH for LH, etc. Will mixing up these LH and RH brackets in the pin wheel cause a problem with pins coming out of the elvator? I noticed they are shaped differently and thought it might. I have a couple of machines that have one different than the rest and it doesn't seem to make much difference, as long as they are straight and tight.Tags: None
Members
- Sep 2004
- 439
- 82-70/BRUNSWICK GSX
- QUBICA CONQUEROR/VECTOR
- KUSTODIAN ION/AUTHORITY22
- ANVILANE
- 1991
Re: Elevator
yes there are RH and LH brackets but if you put them in and tight and stright you shouldnt have any problems........DEFINITION OF MANAGER IN THE 21ST CENTURY: (ADULT BABYSITTER)
- Jan 2003
- 13208
- 1986
Members
- Feb 2004
- 850
- 82/30,82/70,82/90,XL,XLI
- AMF and Qubica
- Various
- wood and synthetic
- 1953
Re: Elevator
yes no problem, use in either hand. they are shaped to help with head first pins, but work fine on both.
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
