Lifelong's hingeless front roller
  • Lifelong's hingeless front roller
    It is quiet as a church mouse.
    Re: Lifelong's hingeless front roller
    is this only in USA , i have not seen this on a 70.Any pictures please.
    Thanks.
      Never mind.
        Here is the Part....
        Front Roller
        Peanut
          <font size="2" face="Verdana, Helvetica, sans-serif">I kind of liked the quiet ka-chunk-ka-chunk-ka-chunk of the rollers. [img]/content/btubb/images/%%GRAEMLIN_URL%%/laugh.gif[/img] They gotta put a ball bearing or a flapper plate on it to 'noise it up' a little, or I'm not interested...
            This is what I was refering to when I stated in a past thread that I was looking forward to there newest item. Supposed to have 1 on order, but it got tabled until after the holidays, I am excited!!
              I put one in today.....I have 4 more in back ready to go.
              I did modify his roller.
              There are collars on the end instead of bearings.
              They are secured with soft bolts.
              I replaced them with grade 8 bolts and jam nuts.
                Good Idea, I will remember that when corporate ok's the order...
                  I just use the conical spring and washer to make'm quiet down.
                    wow, what an impressive idea.
                    Peter
                    Formally Sports Central
                      i have 32 machines all front rollers are welded solid and no problems at all very quiet!!
                        welding does quiet them down, but it eliminates the purpose of the hinge in the 1st place, which is self centering carpet. Just curious 82, what is your average carpet life?? I have had welded rollers for emergency/temp. use, but have never ran them perm. Let us know?
                        not knocking, just curious
                        Paul
                          I ,too, like the muted thunk.(When it CLANKS its broken) It's one of some noises the machine is supposed to make. The only real problem I had was a bad batch of links from JCP. I have never had a tracking problem with carpets. I get 5-6 yrs out of them.
                          I also know a guy who has welded them with no problems
                            The carpets will track with a solid roller if the carpet is made with a 1/16” or less difference on the inside circumference between each side and the hinge pressures are within a few pounds of each other not to mention the pit has to be square.....which is slim to none. Hmmmm....I think I confused myself with that one....
                            In my journeys of trying to find a manufacturer to make our carpets I learned a lot about belting material’s and what causes the tracking issues.
                            Most of the manufacturers that I dealt with were amazed by how the hinged front roller worked. This day and age lasers and pneumatics control it but for a pinsetter the environment is not acceptable nor would it be cost effective. [img]/content/btubb/images/%%GRAEMLIN_URL%%/frown.gif[/img]
                            Please buy MADE IN USA!
                              Those enviro-links (that replace the 597 brass links) do a fantastic job. I''l bet its a lot cheaper than going to the hingeless too.
