82/70 Respot Problem
  • 82/70 Respot Problem
    82/70's, we recieve several calls for machines needing respots...then when we get there, all the pins except what they need respotted will be in their respective cups, and nothing on the pindeck...example: if they need the 4,6,10 respotted, all pins will be in there cups except the 4,6,10, the machine will be on ball 2, and the pindeck will be bare? Anywhere to start would be greatly appreciated.
    Re: 82/70 Respot Problem
    Is this one machine or several.....what scoring do you have?
    Peanut
      my first guess would be your table cable plug is loose, or your ground wire for the table is broken, spuratically not letting the chassis know there are pins left, and then going into a strike cycle. assuming you still use table wiring. . . .then again it wouldnt explain it always bein on 2nd ball. [img]/content/btubb/images/%%GRAEMLIN_URL%%/confused.gif[/img]
        Possible bad roll pin in table drive. Sloppy Solenoid link. Master has the key point though, is this on only 1 machine, or does the problem travel??
          Lets see... several machines...Qubica Scoring...No table Wiring
            if it ends up on second ball ill go with what Dorsin says, tho that would be an amazing Bad TDA Coincidence goin on in several machines
              Yes, that is odd, different machines. I cant see how Quib would have anything to do with it......One question I have to ask, did you see this happen your self, or are you relying on info given to you by another?? Many times over the years I have gone into a situation thinking I had the whole story, and low and behold, pinnie #2 left out a key piece of information.
                Have a look at the offspot switch , if there was an off spot pin in the gutter , the sweep drops, table goes to pick up pins and returns to zero and if off spot switch not correct, sweep runs thro and table respots nothing because it did not pick anything up and it clears away the standing pins.I am fairly confident this is the area to look at , as your machine goes to second ball indicating table has run and also sweep.Does it score correctly on the monitor.
                Please let us know.
                Thanks
                  I was thinking along those lines Maister, thats why I was wondering if he was getting the correct story, as he said there are all pins in cups except the ones called for the respot every time, thats the part that is throwing me, as It would be too co-incidental!!!!...lol, I have to wonder if he saw it himself.
                    Yeah, I'm guessing off-spot switch as well. If you didn't say it happens on more than one machine, I'd be SURE this was the solution. The fact that it happens on a few machines makes that scenario a bit hazy.
                    The second ball thing is the deciding factor for me, but then again it could be a bung table cam switch. Let us know how you go.
                      I'll check the Off-spot Switch today, and yes when I get to the machine it is just as I described before...I don't know if it scores correctly or not (typical counter help).
                        Usually when a table spots over a pin or pins in the fingers (false strike), the pins which are the same as those in the cells are dislodged from the cups, and the others go back up with the cups to the home position.
                        Hypothetical Scenario:
                        Spare left is the 4-5-6. The above mentioned false strike occurs, resulting in 1-2-3-7-8-9-10 in the cups, all 10 in the bin, with the distributor feeding the three "lost spare" pins into the 1, 3, and 2 bins.
                        Are we close? (All I've got so far)
                        False strike with scoring interface can only be the fault of the chassis or board, due to the fact that the table felt for pins.
                        Do you have Elco or C23 chassis with Omega Teks?
                          This is a common problem with Q scoring, specially with the omega tech chassis. still trying to figure it out, will keep posted if I find anything
                            lane, we have Qubica (BES) and mk-70 w/expanders. We even have about 10 black Omega-tek chassis, and I have never had this happen so far, however, it may be the expander that is the key here, as we dont rely on the cell wires.
                              no strike
