This has been a strange week for problems. Tuesday we had to replace a sweep rocker arm assy. and there have been some unusual electrical problems almost everyday. My B mechanic tells me he had to pull a chassis and that I needed to check it out. We put it into another machine to run it. The mach. turns on without a pit light, but the pit light turns on when the table motor runs. The light will also turn on if you pull out on the TA #1 and run the table manually. We did a quick check for trapped wires around the table relay, M relays and fuses. For laughs I un-plugged the table motor and ran the pit light with the TA #1.
The chassis is SS Omega Tek with an expander board. It was after 5 PM and I didn't need the chassis for the weekend, so I packed it away till Monday.
I can't wait to check this out further. I have never seen this problem in over 44 years on 30's and 70's. This should be interesting.
